External grid meter dissappears frequently while charging causing Passthru mode
@robmeerwijk I assumed it was not an old unit as you are running the latest OS. It might be there is a common fault here or perhaps the same symptoms with a different cause.
I am about to go and put a micro SD card in the CCGX and install Venus 3.5 and then monitor what happens, if it fixes it perhaps there is some kind of software bug that in some use cases that affects the later versions of the OS but is not always apparent.
Hi Nick, any luck with version 3.50? I can see from my older messages that the problem started even before 3.50
Hi Rob,
Unfortunately no, I did the rollback and also dis a factory reset using the SD card to hopefully get rid of any accumulated errors but the problem persists.
I posted in the other thread a bit more detail but I think it might be an age related power issue as I have now lost the ability to connect to 2 VE.direct devices at the same time. Grid meter intermittantly dissapearing from CCGX - #11 by NickJenkey
So I think we have similar symptoms but different cause maybe? The fact that the faults seem to be getting more frequent and that there are other comms issues happening make me think that there is some kind of creeping hardware failure.
I am going to replace the CCGX with a Cerbo or Ekrano (Not sure if I want the screen or not really) and also replace the 485 converter too as they are quite cheap and I can use the other one elsewhere less critical.
I just hope that the extra activity on your thread gets more input for you, I go to Victron training days occaisionally and will talk about this issue face to face with someone at some point and see if there is any other ideas.
Best of luck
Nick
