Excess PV transfered Linear into Heating Element
Probably been asked for before, but have not found anything 100% useful.
Would like to be able to dump excess PV Linear into a heating element to help heat up the house when there is excess PV, but would like it to be Linear (not just 2x contactor on/off).
Is there any device from Victron available that can do this or will it need to be DIY? Or are any other manufacturer make items like this.
Node-Red is available for the programming part.
Cerbo GX does not have any analog outputs (for converting excess PV), but probably VE BUS etc. could be used .
Have any one done similar?
Tia Soeren.
Probably need a bit more info of your system. If you are grid connected and feed back into the grid there is AC THOR which is dynamic and you can use in on heating elements, it also connects to victron erquipment.
Hi thanks for info,
Ok, will look into AC Thor.
Have a 3 Phase System with:
3x VICTRON MULTIPLUS II 48/5000/70-50 230V.
1x VICTRON SMARTSOLAR MPPT 450/200 -TR.
1x VICTRON CERBO GX .
1x VICTRON ENERGI METER EM540-3 PHASE 65A (Grid meter).
1x VICTRON LYNX POWER IN.
1x VICTRON LYNX SHUNT VE.CAN.
1x VICTRON LYNX DISTRIBUTOR.
3x battery banks of 4x12V 200Ah batteris.
Grid connected.
Tia.
Any suggestions for an off-grid application?
I have the exact same question - system is sized for EV charging so I have lots of surplus available, I’d like to capture that and dump into resistance heating in a shop slab. I don’t need thermostatically controlled heat in the shop, just want the ability to capture excess potential and take the chill off. I could use contactors to engage one zone at a time, but that would mean some areas of the shop would be really warm, other zones could seldom see surplus. A linear control would really be preferred.
3 phase system with:
3x Multiplus II 48/5000/70-60 120v
1x Smartsolar MPPT 450/200-TR
1x Cerbo GX
1x EVCS-NS
1x Lynx Shunt VE.Can
28kWh LiFePO4 batteries
9.1 kW PV
Fully offgrid
Assuming your underfloor heating is the electrical type then AC Thor can also do that. Have a look at the website. Works well with victron.
I found a small youtube video on how to setup the AC Thor in the Victron ESS, but have lost the link.
Anybody know if it still exist or have been deleted?
Tia Soeren
If you’re grid connected you can either use a Fronius grid meter and Ohmpilot, or use the mentioned ACThor.
If you’re off grid and use frequency shifting to throttle your AC PV inverter, you can 't use the Ohmpilot but you can use the ACThor.
Just for info:
Successfully installed AC Thor 9S into the system.
