EVCS - Power calibration by table
Is there an option to use “Power calibration by table”. I’m using firmware v2.08 and this option is greyed out. Using Single power calibration make is impossible to have accurate power usage values across the whole range of charging current.
Is still possible on 2.08. Have you selected the bullet next to the calibration table button?
if you select it, it will be active
