EV charger manual mode
Hi everyone, I have a Victron EVCS(firmware 2.05), Victron MultiPlus, Cerbo, and LiFePO battery. How can I set up the EVCS so that in manual mode it charges regardless of the battery’s SOC? I understand the SOC settings in automatic mode, but why in manual mode—if the SOC is lower than the “Stop charging at backup battery SoC, if Off Grid (%)” setting—charging doesn’t start and it shows “low SOC”?
según he podido leer, el cargador no esta terminado, aun tienen que ajustar cosas con actualizaciones, i en la carga en modo automático falla como una escopeta vieja.
