Is it the VE bus sending warnings?
The best way to suppress them is edit these set them all to the low cut off of the battery.
The low battery light blinks, i get warning messages on the mail, but no messages on cerbo. Voltages during warning is 52.6 volt. Battery monitor of the bms telles, me voltage ok.
Elsewhere on this forum someone has the same problem and he writes: “I had battery monitor switched on in ve configure, now that’s off, the alarm seems to have disappeared.”.
But the manual explicitly tells you to keep it on when using ess. I could try switching it off, but dont wand to go against the manual.
The best way to suppress them is edit these…
Ok, i can just switch it off, but the battery is not low, and it does not happen wihout ess
When i do that i get an error " value not within boundaries"
I apologise i did not see your reply.
What batteries do you have? What is the technical specification for them?
What are their charge voltages and discharge voltages etc?
How have you programmed the system now. Since it has changed from your original post
I am sorry to. Was very preoccupied with another problem.
Should have told you i was looking at the wrong parameters. You ment the once in the ess helper. I changed these and the alarm is indeed gone
Thank you very much.
