ESS, only use of battery to power loads when there is solar energy to use
Good morning everyone,
I´ve got a configuration with the following elements: MultiPlus-II 24|3000|70, Cerbo-GX, 3 SmartSolar converters, SmartShunt 300 and a 120AH 24V battery.
I´ve set the grid power reference to 0W in order to minimize grid consumption and use the solar energy instead (I don´t want to feed the grid with the surplus energy right now, but if everything goes well I´d like to implement it later via grid feed-in). The thing I don´t understand its why the AC loads are powered by the battery instead of the solar energy via the SmartSolar converters I have (quite a lot of sun right now). I´ve got DVCC activated for the Victron elements.
I will share some screenshots of the configuration I have:
For example, when switching off the MP, the SmartSolar converters charge the battery. However, when activating the MP the solar power goes to 0W and the power its extracted from the batery to power the loads again.
Thank you very much in advance,
Ander
