ESS mode external control registers 37,40 and 41
I used a Python script to read the values from registers 37, 40, and 41. Normally, I receive values around 62,000, but now I am getting values between 900 and 3,000. Is it possible that there is an overrun of the register value itself?
I also tried setting the values in registers 37, 40, and 41 from 62,000 to 60,000 to reduce the power supplied to the grid by -2,000 W per phase. However, I am unable to do this now because the registers are showing strange values between 900 and 3,000.
Does anyone know what might have happened?
Wasn’t the scale factor changed from 0.01 to 1 for some registers in Venus 3.50? In other words. Now you need to use a value between -32768 to 32767 I think :grimacing:
