Hi all, hope to post on correct section.
I have a system with mppt 150/100, a multiplus 5KVa, all under a CCGX, and recently I’ve upgraded my battery pack from a LG chem resu 6.5 to a DIY pack of about 15kwh with a JK BMS
With the old battery, I’ve used for over 6 years, usually I’ve setup ESS to use it from 10 to 100%, leaving a 10% of SOC just for the rarely disconnections or outages from grid
With the new battery I was looking to maximise ESS due I’ve already leaved a margin of change left in the BMS settings ( 0% cell voltage reset a bit higher than under voltage protection)
I noticed if I set any value in ESS settings higher than 5%, inverter work correctly and stop to discharge battery ( for example, I set SOC limit in ESS to 20% and the inverter stop to discharge my pack when reach 20% soc)
But if I set ESS SOC to 0%, multiplus continue to discharge battery over 0%, untill the UVP of the JK BMS disable the discharge
I’m missing something or this is the correct way ESS should work with 0% soc setting?
(Hope to had explained well and sorry for my bad English)
