Hi
The app shows error #21 on one of my five MPPT.
I have tried to change the MPPT to one i know works, same problem.
I have change the solar panels to those which works on another MPPT, same problem.
I have measured the voltage on the battery connection on the MPPT it shows 13,2 V at the same time the APP shows between 15 and 16 V.
When I disconnect all cables from the MPPT and connect them again without the PV connected it show the battery voltage 13.2 V when i connect the PV the battery voltage goes up to 15-16 V.
i have measured the cables between the solar panels and the MPPT and they seems to be good.
The first time the problem showed up was when we reconnect the solar after some work on the wood deck on our boat.
What do I do to solve this problem?
Br
Erik
