Hi all, I just installed a system with two quattro 10kVA, one smartsolar 250/100, one Ekrano gx and two fronius primo 6.0.
I am using Cegasa eBick Pro 280 batteries, that are connected to Ekrano gx through can bus. At first it looked like Ekrano gx was reading the battery bms correctly, but I now notice that it only reports correct values when charging the battery. When I am discharging the battery I still see the correct battery voltage, but current is 0.
I am attaching some screenshots to show this behavior.
Does anybody know why could this be? if a bad configuration from my part or if there is a problem with the BMS. BMS is connected to CAN port 1 of Ekrano gx, configured as CAN-bus BMS LV (500kbps). I tried on CAN port 2 as CAN-bus BMS HV (500kbps) but it wouldn’t detect the BMS that way.
I followed these instructions for configuration https://www.victronenergy.com/live/battery_compatibility:cegasa
