All working fine the evening before and when main rocker switch was turned to INVERT OFF. Next morning entire unit was discovered ‘dead’: NO DISPLAY, NO OUTPUT, NO SOUND. Unit about 5 years old.
Tested all fuses, external and internal, to be ok and 52V at both internal 48V DC power input posts.
Disconnected battery bank for 1+ hrs, then re-connected. No change.
Disconnected T-sense, re-connected. No change.
Unplugged and reconnected all connections to Color Control unit.
No unusual smell or visual signs of damage internally (both front cover plates removed for inspection).
I did contact my seller and they didn’t have any help other than to contact Victron for help. 48 hrs later and they still have had no response from Victron.
The EasySolar is now uninstalled and in my car since I’m on the ferry to the mainland tomorrow morning and not returning for 3 weeks.
I don’t know if I have a MK3 interface - I think I do, is it the RJ45-USB adaptor?
I sincerely hope it’s not an easy fix like disconnecting a ribbon cable! That would be the ultimate in annoyance.
Unit was shipped to Victron UK and the issue was found to be with the CCGX screen, and Victron has now fixed it under warranty. It was just within the 5yr warranty period.
