I’m using the relay to start a car charger at 75% charger and stopping it at 50% charge, that works fine.
Problem is that at 75% the inverter reduces solar power and prioritizes battery it should prioritize solar
I can’t see how to change that any ideas
Ypu are definitely going to need to share nore information here.
What components do you have?
How are they programmed?
Any ither considerations for you install design?
Details like - the relay on what?
Ludo
3
Starting at v508 you can prioritize solar energy in multiplus/quattro.
Easy Solar has got a inbuilt programmable relay
V508 is that firmware update ? I updated about a month ago and will look which I have.
Ludo
5
Yes, but the current version is 556
Issue corrected - conflict on battery monitor settings.
Thanks
