Is it still necessary to set DVCC to 52.4 volts?
I seem to remember reading that charging is now interrupted when one cell exceeds 3.5 volts.
I disabled it once for testing and checked the cell voltages. One cell rose to 3.507 volts, while the lowest was at 3.474 volts. I then re-enabled it as a precaution.
What is best for the batteries now: set it to 52.4 volts, in which case my batteries show 52.1 to 52.2 volts, or disable it?
