Doesn't Victron's MPPT support parallel connection below 48V?
when I add second MPPT within Victron’s MPPT sizing calculator, I get the following message:
“Lower voltages not supported with multiple trackers”
and it only allows to select 48V systems.
Does that mean MPPT cannot be connected in parallel in a 24V system?
Hi @zsoerenm,
The only Victron products that have more than 1 MPPT tracker are our 48V only RS models.
24V MPPTs can be connected in parallel, but they only have a single tracker per MPPT, so you will need to treat them separately and only use 1 tracker in the MPPT calculator.
The calculator will not recommend multiple MPPTs.
So if you specify 2 MPPT strings are required, then it will only recommend the models that have multiple trackers built in.
