Display Phoenix Load in VRM
Hi All,
In using VRM, I would like to display the loads of my small Phoenix 12-250 inverter as well as my Multiplus II 12/3000/120-50. At present, the AC loads displayed in VRM mirror the loads from the Multiplus II, but there is no indication of the loads for the Phoenix inverter (shy of subtracting the Multiplus watts from the total battery discharge watts). This is an off-grid system with a CerboGX, to which the Multiplus is connected via VE.bus and the Phoenix inverter is connected via VE.Direct. Both are seen in remote console. My Phoenix inverter is only running critical loads, which would be very helpful to see in VRM. The Multiplus provides the main household
power when we are present, and is shut off when we leave the house (Phoenix inverter always stays on). Any advice would be greatly appreciated.
I think there’s a bug in the Phoenix inverter or VRM portal. I tried displaying the power output of my 12V 500W inverter on the Advanced page of the VRM portal but it is always zero.
My solution was to create a Node-red dashboard which multiplies inverter output voltage by output current and showing that on a gauge.
