Discharging to too low target SoC in DESS at end of day
Hi, I have 3 phase installation: 3 MPII 5000, 20kW battery, SolarEdge solar 4kW Peak. I have dynamic energy contract and DESS enabled. Works nicely and stable.
There is one thing that could be optimized when the system decided to discharge the batteries at the end of the day when the energy price is high. The system discharge mostly to a SoC of 30% and I have a minimum of 20%. So for the evening and night I only have 10% of battery capacity to use (equals 2kW). My average consumption is 250W. So 8 hour running on battery. Effectively I use 4 hours grid-power in the morning because the SoC of the batteries is 20%. In the morning the energy price is higher than during daytime. And this is from my perspective a easy predition the system can do. For the records: this behaviour I have for months.
Only when the system expect low solar power the next day, it set the target SoC at end of day higher, like 50% , doesn’t discharge at all. And that is the expected behaviour.
Based on historical data I would like to set the target SoC end of day not lower than 40%. I didn’t find a setting to adjust this. Or is this an improvement to the algoritm?
Please advise? I can share screenshots.
Thanks.
Hi Kevin, maybe I did not fully understand your situation, but why don’t you lower your SOC to 10% in the evening with feed-in disabled until the next morning (e.g. with a simple automated script) to solve your first issue? It is a known limitation of DESS that it only optimizes based on deterministic logic and you currently you will not get the behaviour you expect inside DESS without adding your own logic. And this can quickly get very compliated if you add components that implement self optimization based on machine learning. Maybe if you check back on DESS in 2027 you could find that your issues have been solved :slightly_smiling_face:
HI Recorp, thank you for your reply and suggestion. You might be right about 2027. Especially in NL because our reward system for selling energy will change. In the meantime I switched my energy supplier and switch to trading mode which is now very profitable. Let’s see in 2027 if I still need to make some scripts to fulfill my wishes. thank!
