DESS with a heat pump - feature request
@dfaber I have an idea to improve the consumption forecast for heat pump. Most heat pumps operate with weather compensation, so the colder it is the more energy.
Given it shows the temperature data in VRM, could you not let people select if they have a heat pump, and then you know what baseload to expect based on the weather.
