I currently have an ESS setup with a Multiplus-II, Smartsolar and pylonthech batteries. As I have no interest in feeding back excess energy into the grid and particular oddities relating to the local grid setup (3 phase delta) and regulations, I want to change my setup to ‘off-grid’ but with grid backup.
To achieve this (and to comply with local regulations), I need to DC couple a charger with the DC bus. And the charger must not be able to act as an inverter.
Current setup: Grid => Multiplus => DC bus <= Batteries/Solar
Wanted setup: Grid => Charger => DC bus <= Multiplus/solar/batteries
The key point here is that charger is not, and cannot be an inverter. Ie, if I would use a multiplus as dedicated charger by setting the switch to ‘charger only’, I would still not comply with local reg.
So my question is:
- Is there a victron charger that can be used in this situation. And i’m thinking about DVCC. Also the dedicated 48v chargers all seem to be stand-alone units
- Or, is it possible to have a multiplus (or other) factory locked into charger mode (as that would be accepted by reg.)
- Would it be possible to use a standalone charger in combination with smart batteries (BMS) if this charger cannot communicate with the battery. ( BMS is already connected to the cerbo), in terms of voltage, charge current, state of charge etc.
Thanks for your input!
