Daylight saving time not applied to generator start stop function possible software bug
During the change of minus one hour this weekend the generator start stop funcion on the cerbo stays the same.
Sunday morning (27/10/2024) the clock went backwards in effect 02:00 became 01:00.
My current setup is a multiplus 2 10k set to ignore AC input except when a signal is received from the cerbo relay.
This in effect turns on the multiplus at 22:05 everyday to charge the batteries, it turns off again at 05:55
On the eveing of the 27th at 21:05 the relay turned on and the multiplus accepted AC in.
I checked the time on the cerbo and VRM all location and time settings are correct and the correct time is shown.
The following morning at 04:55 the cerbo relay / multiplus stopped and ignored AC a full hour before it should.
It seems there is a bug where the generator periodic run is not updated with the new time.
Can anyone elese verify this?
Fortunately i took pictures of the above if needed, but it just shows the generator starting and stopping in the hour before it’s supposed to.
i will wait to see this evening if the problem persists. then reset the cerbo.
If the reset fixes it then i can only guess at a software bug.
Current Cerbo firmware - 3.50/34
Update 28/10/2024 21:05 - Relay not activated. Hopefully back to normal, waiting until 22:05.
Final update - Everything is working correctly. I have not reset or touched anything.
Looks like the first 24hrs were the problem not a major issue I just ended up without a fully charged house battery for the day as the car was charged for an hour from the house battery.
I noticed another post where this behaviour had occurred on DESS.
