Dashboard has no graph for "grid"
as below, it just says “No data to display”. The other options from the dropdown (System Overview, Solar, Consumption) work OK and their graphs display OK. (This is not the same fault as recently affected old versions of iOS, as it occurs with Firefox on a laptop as well as my old iPhone.)
recently
Hi @sharpener ,
I can see that for today, the graph shows data. You just use the grid very little, so when there is nothing to report, this is the view you see :slight_smile: .
Hope that helps!
OK thanks. Yes the very small amount of usage today illustrates it well. I will be using more next week.
