Hi! Is it possible to connect like this? Will it work or domestic battery can’t take current from alternator without dempher (starter battery)?
The alternator might not start producing energy without a battery connected to it.
Most (or all?) alternators need a battery to create the magnetic field needed to produce energy.
You might have to add a diode across 87 and 30.
Actually you wouldn’t even need the cyrix in that setup.
