Consommation erronée sur le graphique cumulé du VRM
Les données cumulées de la consommation sur le graphique du VRM sont complètement erronées, alors que la consommation CA instantanée est correcte. J’ai l’impression que le graphique affiche des KWh à la place des Wh, mais je n’ai pas trouvé de paramètre pour rectifier cela.
try translating the question svp ?
The cumulative consumption data on the VRM graph is completely wrong, while the instantaneous AC consumption is correct. It seem that the graph is displaying KWh instead of Wh, and I have not found a setting to fix this problem.
I have seen similar posts like this i think, have you search for it ?
Yes of course, I don’t know if I don’t use the good keywords but I don’t find anything on this subject
My advice would be to re-post this question with an English title .
I am not into the graphical user interface of the system and was just trying to guide you a little bit. For the short while i am hanging around on this forum it seems that Dutch, German and mainly English are the languages to write in to.
