Connecting 2 Phoenix Compact 12/1200 Inverters to a single Cerbo GX using VE.bus
I have a Phoenix Compact 12/1200 inverter connected to a Cerbo GX using the VE.bus, everything is working great.
I’m looking to purchase a second Phoenix Compact 12/1200 inverter to provide a larger AC power supply.
My questions are
  1. Can I connect both of the inverters to the same Cerbo GX using the VE.bus?
  2. How should I configure the 2 inverters?
Any help would be most helpful.
I just received my 2nd 12/1200 today, got it all hooked up, (i’m using VE.Direct to USB cables to go from the inverters to the cerbo gx) My VRM is displaying in the AC Loads the total output of the 2 inverters, and has L1 listed with the same value. I was wondering if there was any way to get the VRM to display the two inverters separately like my 3 MPPT charge controllers are listed. Like have an L1 and an L2 that shows the separate inverter’s loads, then the big box at the top could show the total as it’s doing now.
