Hi and welcome.
I too run wind turbines with Victron kit.
You don’t say what Wind Turbine you have, knowing this will help us help you. Can you give us a link to it please.
You will need a dedicated controller for your turbine (i purchased the MC2 controller with the turbine), see below for a typical but simple setup (without showing the smart shunts i have installed).
Not sure how well the Digital 440 Amp Charge Controller with Divert Relay & LED Volt Meter for Wind and Solar. would work.
I would look around for other controllers so you can compare their functions. I am sure others here will have some helpful suggestions too.
