Hi.  Does anyone know what differences there are between the Multiplus compact inverter charger (CMP242200100) and the non-compact version (PMP242200100)?  Are the features the same but one is smaller and lighter than the other?
Thanks,
Tim
The non-Compact weighs about 6.5-ish pounds more, has a steel case instead of aluminum, is about 0.5" shorter, 0.75" narrower, and 0.9" thicker, and has an internal construction and layout that makes it a bit more rugged for high-vibration mobile or other environments.
…And arguably looks a bit cooler, since it uses the newer MultiPlus-II style casing and LEDs.
