Buenas noches,
Tengo un velero al cual queremos instalar tanto la batería de arranque como las de servicio de LITIO, ¿ Que necesitamos a parte del Orion TR-Aislado?
Buenas noches,
Unfortunately, until alternator tech catches up with lithium batteries, it’s best to keep the starter battery an AGM type.
This is because, if the lithium stater battery disconnects due to over-voltage, then the Alternator can dump it’s load into it’s rectifier and regulator. This causes a big over voltage spike - can be up to 80V (rep), and usually cooks either the regulator or the rectifier or both - also anything else connected to the output.
So it’s also good practice to use a dc/dc converter to separate the lithium house batteries from the starter battery / alternator circuit.
Some smart regulators may be able to cope with lithium batteries as both starter and house, but these tend to need communication with BMS / GX control system.
Another thought is if you do go for lithium as a starter battery, do make sure it can handle the cranking current.
