Hi everyone,
I have a setup question regarding my campervan’s battery system. Here’s my current configuration:
- Main leisure battery: Smart LiFePO4 12.8V/200Ah with Smart BMS 12/200
- The starter battery is connected to the BMS through the Alternator+ connector
- This allows charging the leisure battery from the alternator
The issue: I’ve realized that I can’t charge my starter battery from the leisure battery because the Alternator+ connection on the BMS only allows one-way current flow (from alternator to leisure battery).
I’m looking for suggestions on the simplest way to enable bi-directional charging between the two batteries. Ideally, I’d like to find a solution that allows me to keep using the Smart BMS 12/200, rather than replacing it with different equipment.
Has anyone solved this issue in their setup? What additional components might I need?
Thank you in advance for your help!
