Charging Battery via 230V VTL from Car
Hello have an offgrid cabin
With solar charging and honda aggregat used i vinter season ,all Victron equipment
Multiplus inverter 5kw
Just bought a Renault 5 with VTL
And with this, is possible to power Charging with 230V from the car.
The inverter is turning to bulk a second or 2
And tripping out and turning back to inverting
Any who have a solution on this problem?
Brg
Vega
Hi i think tou will have to change the gridcode and/or take a look at the ground relay settings in the multiplus
Since your off grid you should be able to get it working,
VTL on grid is only possible with a separate battery charger
Hi, have a look at my previous post on the same topic.
Thanks, for your reply and solutions :+1:
Brg
Vega
Sendt fra Outlook for Android
