Changing name of the battery
Dear all
Any idea where the name of this battery can be changed?
Can’t find it.
Thanks.
In the device list itself in the device list on the gx -sometimes you can rename it there
Cannot find it there…
Are you using a shunt?
I am really a beginner. But in the list of my devices it shows a SmartShunt IP65.
Ok use Bluetooth to rename the shunt on the shunt. It will change
I can see everything but the name of this battery I cannot find. No idea where this is hidden…
That might be the name on the inverter then.
You can change that in device list on the GX
No it seems to be the name of the battery.
Went through all the menus but cannot not find.
Is there nobody out there who knows how to change that name?
I dont even have that additional field in any of my installations. Fells like its an additional battery measurment, perhaps from a Smart Battery Sense while the main battery panel is filled with information from the BMS?
What does your system look like, what kind of devices do you use in it?
Show the VRM device view.
If you delete the missing orion does it go away?
Though it seems to be active with a reading so you could try trace it out by finding the device with corresponding metrics.
I guess the missing Orion was not active for the last two days?
Unfortunatley I am 10.000 km away from the car.
You can remove it from vrm remotely. Should be a delete button.
Yes I know. But I do not need it?
It will reappear when it is online but rather not mess with it to be safe since it isn’t missing but off.
I would suggest you try rename each device and see if it changes. Usually you would expect to see that name in the UI device list. It may well be your Orion and because its offline it isn’t visible
It is the name of the inverter.
As found in the devices list.
Weird if doesn’t match the device name in vrm
