Change default tab in Levels menu
As start page I use the “Brief” menu which displays the tank levels. Thus, when I go in the “Levels” menu, it is to get the temperatures in the “Environment” tab but the “Tank” tab is showed by default which is quite annoying.
I don’t think it is convenient to display the same information twice by default in two different menus.
If not making “Environment” tab the default tab of the “Levels” menu (eventually moving it to the first position which would be the alphabetical logical place), can we have a settings to make it so ?
Thanks,
Lucien
