cerboxGX shows Fronius Primo with 3-phases ?!?
Everything works fine so far, but why the pv-inverter is shown with 3-phases on my 1-phase system, , for what reason and how to fix this?
thank you for reading.
It’s only using Phase1 for data. The UI is just setup to display a 3 phase inverter as well. You can just ignore that in this case.
this is the way it’s supposed to work?
I think so.
can anyone confirm that the fornius primo is always displayed with 3 phases, even though the inverter is 1-phase?
I assume you have a three phase supply to your house. With a three phase grid meter connected to the Cerbo.
The pages you are showing are the setup of your Fronius to tell the Cerbo on which phase the Fronius is connected. This is necessary to be able to calculate the energy use and feed in.
So yes, this is how it is supposed to work. In normal use, you are not going to go near these pages again. There is no need to.
thank you for trying to help, but my system is 1-phase only, my gridmeter is a vm-3p75ct configured as 1-phase.
i am little confused because i thought fronius is well integrated in den victron environment, i even can’*t see the daily yield from the inverter, only accumulated overall yield - little frustrated about that only the absolute basics are working as expected
I do not see this on my just updated 3.71 VenusOS
The integration was hands off - discovered and displayed both 8.2 master/slave Primos over my local ethernet. I was actually not happy need to look at acl’s but it works fine.
