Hi all,
Cerbox-GX
Firmware version 3.55
Running into a challenge with using a Globalsat N363N5 4800 BAUD USB gps receiver. When I plug it in, the GPS unit has a fix indicated by flashing red light but not present in list under GPS.
Detecting
root@einstein:~# cat /dev/ttyUSB0
[ 2.320662] usb 2-1.2: New USB device found, idVendor=067b, idProduct=23a3, bcdDevice= 1.05
[ 2.329184] usb 2-1.2: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 2.336758] usb 2-1.2: Product: USB-Serial Controller
[ 2.342096] usb 2-1.2: Manufacturer: Prolific Technology Inc.
[ 2.348090] usb 2-1.2: SerialNumber: BWAHb115819
[ 2.399567] usbcore: registered new interface driver btusb
[ 2.723772] usbcore: registered new interface driver rtl8723du
[ 3.295606] usbcore: registered new interface driver usbserial_generic
[ 3.302524] usbserial: USB Serial support registered for generic
[ 3.332901] usbcore: registered new interface driver pl2303
[ 3.338709] usbserial: USB Serial support registered for pl2303
[ 3.366674] usb 2-1.2: pl2303 converter now attached to ttyUSB0
GPS stream working
screen /dev/ttyUSB0 4800
$GNGSA,A,2,01,112,02,01,09,32,21,124,,,,0.86,0.16,0.61,7*0C
Still no GPS connected
Found this directory
root@einstein:/opt/victronenergy# ls
can-bus-bms dbus-imt-si-rs485tc dbus-systemcalc-py mk2vsc vecan-dbus
dbus-acsystem dbus-modbus-client dbus-tempsensor-relay mqtt-rpc vedirect-interface
dbus-adc dbus-modbustcp dbus-valence netmon venus-access
dbus-ble-networking dbus-modem dbus-vebus-to-pvinverter prodtest venus-button-handler
dbus-ble-sensors dbus-motordrive firmware serial-starter venus-eeprom
dbus-bornay-windplus dbus-mqtt gps-dbus service venus-firmware-update
dbus-cgwacs dbus-parallel-bms gui service-advertiser venus-platform
dbus-digitalinputs dbus-pump gui-v2 service-templates version
dbus-fronius dbus-recorder hub4control ssh-tunnel vesmart-server
dbus-fzsonick-48tl dbus-rv-c localsettings swupdate-scripts vrmlogger
dbus-generator-starter dbus-shelly mk2-dbus themes websockify-c
root@einstein:/opt/victronenergy# cd serial-starter/
root@einstein:/opt/victronenergy/serial-starter# ls
cleanup.sh functions.sh run-service.sh serial-starter.sh start-tty.sh stop-tty.sh
Running this script actually makes it work
root@einstein:/opt/victronenergy/serial-starter# ./serial-starter.sh
serstart starting
INFO: loading config file /etc/venus/serial-starter.conf
INFO: Create daemontools service vedirect-interface.ttyUSB0
INFO: Start service vedirect-interface.ttyUSB0 once
INFO: Start service gps-dbus.ttyUSB0 once
Then I can actually see the MQTT values under GPS
gps
▼0
Connected = {"value":1}
▼Position
Latitude = {"value":-32.29}
Longitude = {"value":115.72}
However on reboot, this is not persistent and but can replicate by rerunning serial-starter.
- is this expected behavior? I want to use MQTT to capture positioning without needing to add a cron job or adding this script to startup manually, per cerbo.
Cheers
