Hello Friends!
I have one boat with the following issue.
When Inverter Phoenix Smart 12/1600 conncted thru Ve.direct to Cerbo GX is power on the Cerbo GX re-boot. This happen when Inverter is switched on for the first time after a while.
If it switched off and on again the GX reboot doesn’t happen anymore.
If you disconnect ve.direct cable from Inverter to Cerbo in the same conditions the GX doesn’t reboot
It seems that there is a peak of current on Ve.direct that switch off Cerbo GX for a while
All power connections are checked as following:
- The Cerbo directly on the battery bank
- The inverter positive goes from the bus bar of the inverter and with a switch and fuse in the middle, negative goes directly to negative busbar
All the equipment have the latest firmware release
Any idea?
