Cerbo GX unable to detect NMEA2000 tank senders through engine gateway
Im using a Victron system on my boat with a Cerbo GX device. I would like to display tank levels from Fresh water & Fuel tanks as well. The tanks are connected to the EVC system from Volvo Penta and a Volvo Penta N2K gateway (Easy Connect) is installed. THe Cerbo GX also have a N2K cable installed and connected to the N2K backbone.
The tank levels are available on the N2K bus as I can see them on my MFD as well as the Victron devices.
The Cerbo GX also lists the Volvo Penta gateway under visible devices but I cant see the tank levels anywhere. Do I need to configure something manually on the Cerbo or is the VP gateway simply not supported?
Unfortunately I cant find any detailed info around PGN’s for the VP gateway but the MFD can display the tank levels with no issue.
Many thanks in advance.
Anyone?
I have a similar issue but with a Raymarine gateway. Data is available on N2k but doesn’t show up on the GX device. Any insight?
