Cerbo gx RJ45 port
My cerbo GX is connected to a pc through a Ethernet cable. So I can display it on the display . I can’t use a HDMI cable. Now the RJ 45 port is used. However i want use it to connect to nmea2000 with appropriate cable.
Will it work if I install a switch?
Connects with CAN which is a totaly different port to the ethernet. So there should not be a problem.
Will what work if you install a switch the display on the PC?
I think he meant a network switch on the Ethernet cable…
Correct. Network switch
