Cerbo-GX no longer starts
Hello, my Cerbo-GX no longer starts.
The WIFI LED flashes orange 3 times briefly and 1 time long, in a continuous loop.
I’ve also tried to do a factory reset with an SD card, but it starts up with an error.
Message on the display:
Searching for installer image…
Installer image found on mmcblk0p1
Creating portions…
Error installing software
When trying to do a factory reset, the WIFI LED blinks continuously.
who can help me
Thanks Harald
Did you follow the reset procedure in the manual exactly? Section 18.1
reset:
How to reset a GX device to factory default settings:
  1. Download the venus-data-90-reset-all.tgz file.
  2. Copy the file onto a blank, freshly formatted FAT32 USB-drive/SD card (don’t unpack or unzip that file, don’t rename it ).
    If the GX device is running firmware between versions 2.12 and 3.10, only executing a single file is supported. Either update
    the firmware on the GX device first or rename the downloaded file to venus-data.tgz before putting it on the removable
    media.
  3. Boot with the USB-drive/SD card inserted and wait until the GX device has fully started up.
  4. Remove the USB-drive/SD card from the GX device.
  5. Power cycle the device, or, alternatively and when available, use the Reboot function in the Settings → General menu.
    This will reset the settings on the GX device to their factory defaults.
May be too late to do that now so 18.2 applies, some times the wrong file has been used.
I had a similar issue, and the trick to resolving this was HOW the recovery sd card was created.
The file that you download from Victron is a compressed file AND MUST be decompressed BEFORE you ask the disk image writer to create the sd card with it. If you have the experience and the correct tools, accessing the internal serial console also gives a great amount of help as to what the cerbo is actually doing during the boot process.
Follow:18. Reset to factory defaults and Venus OS reinstall
you need to follow this precisely to achieve the final result.
