I have ESP32’s setup and successfully sending data from an attached BME280 (temperature/humidity/pressure) sensor sending data via MQTT to my Cerbo GX. I’m wondering the best way to integrate this into the solution. I set up an “Environment” tab in my Node-RED dashboard and I’m able to drive gauges for sensor values. I feel like I’ve seen people integrate temperature values into their Venus UI though and I’m not sure how that’s set up. Can you get temperatures onto the gui-v2 Brief screen somehow? So far I’m just counting on using the values for custom dashboard and logic through Node-RED. Thanks.
Related topics
| Topic | Replies | Views | Activity | |
| Import sensors through internal MQTT | 6 | 727 | 17 August 2024 | |
| Display temperatures on touchscreen | 2 | 211 | 31 October 2024 | |
| Compatible BT temperature sensors | 4 | 1250 | 6 January 2025 | |
| Display temp on second (aux batterys) | 0 | 39 | 28 December 2024 | |
| Cerbo GX temp sensor to Brief Page | 1 | 48 | 11 June 2025 |
