I’ve have a battery in a system and the manufacturer it’s not making more of this model, I’ve found another battery that has the same specs. Both are 16S LiFePo4, so, may I install the other battery on the other Can Port so I can check the state of both batteries in the VRM? I will install a SmartShunt to get a unificated SOC of both batteries. Thank you in advance.
yes. there is also a bms integration service fr adding battery totals.
I know there’s a system to make an integration. I prefer the smart shunt. Thank you for your answer, have you tested it by yourself?
No; I built my own BMS.
There are ohtrer posts on line about the battery agregator service, or you can just connect the 2 different BMS to the 2 different CAN ports.
I’ve found a thread about this. There’s a bug that gives the same ID to the two different batteries on the two different CAN BUS’es
I think that the ID’s can be modified in the Cerbo to distinguish between the 2 sets, but this has to be done manually. (VRM ID’s)
Do you have any information on how to do it?? TYIA
Settings>VRM>VRM device instances menu.
Thank you very much, now I only need to test it!!
