My Ruuvi temp sensors display in VRM shows a minimum temp of 32F and a max of 68F. As a result, it’s almost always maxed out at 68, as the actual temps are warmer. Is there any way to adjust the max and min temps on the display for greater range?
See screenshot below, follow settings, devices to your ruuvi, then setup and type and choose a type with a better temperature range.
Ranges for each type are as follows (in degC, don’t know about degF):
Battery : -20C to +60C
Fridge : 0C to +20C
Generic : -40C to +60C
Room : +5C to +35C
Outdoor : -40C to +60C
Water heater : 0C to +100C
Freezer : -30C to 0C
