Can anyone suggest an advanced programmable 12 V battery monitor & relay that doesn't use a shunt?
I’m looking for a 12 V battery monitor that doesn’t use a shunt, but can be programmed to trigger a relay on voltage conditions I define instead of the pre-programmed selectable variety - like the BMV 712 but without the shunt.
Many thanks
Provided it’s for Lead Acid batteries then a Smartgauge will do what you need. It’s old tech with the advent of LifePo4 batteries but works well with LA or AGM.
Sterling suggestion! It is indeed for lead acid batteries.
Many thanks
You can use a shelly uni to measure voltage and control a relay. Another shelly device. I do this very cheap, AC DC.
