Can a 30ah lithium battery power a caravan fridge for 40 hours
Hi new user. I have a phoenix 12/250va inverter with a 30ah lithium battery.
Am I ok to power a caravan fridge pulling 0.7amps for 40 hrs
Sorry for being a thicko :thinking:
I would say no because it is right on the edge. 0.7A for 40 hours is 28Ah (multiply 0.7 by 40). If the battery was at 100% full it would end up at 6.7% full, ideally you do not want to discharge below 10%, ideally 20%. A 35Ah or 40Ah battery would be better giving more margin.
Thanks for the advice. Also have a victron 75/10
Solar controller with 100w panel(only charging this battery). Would that help.
Prpbably not enough PV. I also have a 100W panel on a 75/10, charging a 120Ah AGM which mainly powers a Waeco/Dometic CF35. Its not enough PV power to let the car stand for days and keep the fridge powered. About every three days i either need to plug a charger in or use the car for an hour to recharge the aux battery.
But i guess it also doesnt help that in places with lots of sun the car quickly gets hot inside which lets the fridge work harder, and vise versa.
Thanks for the advice. Will upgrade I think.
