Bug - Tank notification levels cannot be changed in firmware 3.54 New UI
Testing the new GUI in the past few days. Cerbo GX with firmware v3.54, using ‘New UI’
Tank Sensor high level alarm
  • Active level and Restore level cannot be changed, the value that you enter is not stored
  • tried disabling/re-enabling the analog input, does not fix issue
  • tried disabling/re-enabling the alarm, does not fix issue
  • Active level can only be 90% and Restore level can only be 80%. No other values are accepted.
Same behavior noted with tank sensor low level alarm
These senders are 0-180 Ohm.
When I switch back to classic UI, these problems are not present and I can set any value.
Just reporting what I have observed with my system. Get back to me with any questions. If I missed something please let me know.
Greetings from Ontario Canada.
Hi @VanLife3D ; yes reproduced here and not good indeed!
Thanks for the report and we’ll fix this urgently. As a work around you can change the settings using Remote Console.
Is this problem fixed?
Its fixed in the latest beta version (v3.60~39). And will be available as v3.55 official release soon.
Meanwhile, you can also work around amend them in a webbrowser, ie. the remote console function.
