Hi, I have this battery charger since yesterday and I’m surprized by it strange behavior. Several times when I plugged the charger on main 230v all the leds (4 blue / 4 yellow) blinks alternatively during 15-20 seconds but not every time. During this times, nothing can be selected with mode button. After that the led test comes on, switching immeditely to “bulk” and then to “abs”. in approx 5 sec. This behavior happens with or without battery previously connected. It occured 4-5 times since I received it yesterday during my tests. I tryied a return to factory setting without success. Other strange behavior. If I disconnect the battery during charge (whatever the state), the charger continue to charge as if nothing happened, it doesn’t see that the battery is disconnected. Could please tell me if it is normal or if my unit is faulty ? I don’t see anything about that on the user guide. Thank you for your assistance. Best regards. Gilles
Related topics
| Topic | Replies | Views | Activity | |
| IP67 charger - update v3.65 | 0 | 73 | 11 February 2026 | |
| Victron 30 - 3 outputs | 2 | 57 | 14 June 2026 | |
| Does FW update V3.65 fix charging problem (alternating bulk/abs) with charger Blue Smart IP65 12/15? | 17 | 995 | 30 March 2026 | |
| Smart IP65 Charger 15A/12V not charging, switching between bulk and abs, after firmware update | 25 | 4869 | 28 February 2025 | |
| Blue Smart IP65 12/15 charger not charging LiFePo4 battery | 1 | 259 | 7 August 2025 |
