Hi, I have a single standard 12v boat battery to start the engine and run lights etc.
What would I need to connect it to a solar panel to maintain it? As well as check the voltage etc. Looking for the simplest/cheapest option which I could then long-term potentially add a leisure battery to etc etc… I also want to run a 12v fan from the battery to help with humidity etc but I’ll probably just connect that directly to the battery.
Thanks in advance.
