BMV 712 Smart Shunt Incorrect State of Charge
Your settings are fine, charged voltage is ideally 0.1V below absorption set on the chargers.
Your problem is the Inverter must he connected to the load side of the shunt. The shunt counts power in during charging and power out when using loads to get to the SOC, so you have not been counting your inverter load.
See the diagram in the post below
