BMV-712 Data Logging
In the VictronConnect manual it says that data is stored at an interval of 30 minutes, for 46 days. However, on the same page the Trending screen captures of the app show data with a much shorter capture interval. Is it possible that that should have read 30 seconds?
I don’t see anything about setting a clock/calendar in the BMV-712 manual, so can I assume that the trend time stamps are back calculated from the current time/date on the device running the app?
Recent data is stored at a shorter intervals and then later averaged into intervals larger intervals, upto 30 minutes.
And the timestamps are indeed calculated from the current time and a previous time that was stored inside BMV-712.
With kind regards,
Thiemo van Engelen
