BMS High Voltage
There are some threads on this forum with the tag felicity-solar [i have added the tag here if you tap it it will take you to others marked the same way] and Angie-Felicity on them.
You should never need to do this. There is something else that needs attention here.
Also sometimes when batteries are new it is an expectation of that until they settle a bit.
