Dear Victron Friends,
I’m facing the following issue on one of my last installations:
BMS 12/100 CL ALTERNATOR STARTER BATTERY POSITIVE STUB shows a voltage of 13,36V even if starter battery and alternator are disconnected from the pole.
House batteries (3 x LFP-SMART 12/200) voltage is 14,2V during absorpion and 13,5V on float.
It seems that there is a parallel between ALT pole and LI-ION+ one (even if with a low voltage drop)
If I disconnect House battery and I connect Starter the BMS switch on
Is that normal? If yes, Why?
Thanks a lot
