What is the output voltage and max amps on a 24v input voltage. Is it possible to use two 104 cell panels? Thanks
CbiTony
(Tony)
1
Justin
(Justin)
2
That depends on which version you choose; have a look at the datasheets and user manuals: https://www.victronenergy.com/technical-support?product_id=231
Related topics
| Topic | Replies | Views | Activity | |
| SmartSolar MPPT 100/20 Charger Ruhestrom aus Batterie | 2 | 90 | 14 March 2025 | |
| Victron VRM API Integration für Home Assistant | 44 | 2333 | 28 April 2026 | |
| App Setting SmartSolar MPPT Solar Charge Controller 100/50 With 600 Amp Batteries | 1 | 65 | 27 July 2025 | |
| Parallel/parallel connection, night time voltage dropping and other yummy stuffs😵💫 | 168 | 2055 | 1 November 2024 | |
| BlueSolar PWM DUO LCD&USB 12/24V 20A | 5 | 97 | 24 January 2025 |
