Blue Smart IP65 12v/15 won’t charge
I recently purchased the blue smart 65 12/15 amp charger as I wanted something to keep my batteries topped off while using lights and 12 volt appliances. I am a semi- truck driver so my setup is 4 lead acid 100ah batteries. Wasn’t too concerned with charging them as my alternator on my semi would do the job, just wanted to make sure I’d have enough juice to restart the truck.
First night I used it, I put it in power supply mode and it instantly put out 15 amps. Went to sleep and woke up to only 1 amp even though the load size hasn’t changed. Now the charger no matter what settings I try won’t put out more than 1amp usually hovering around .7 amps. It detects the battery voltage but never goes higher than 12.5 when it says it’s charging. Quickly goes from bulk to absorption even though the batteries can show 12.2 volts. When I restart the truck the alternator instantly puts out 50+ amps which lets me know the batteries definitely need a charge. They are all brand new as well only 4 months old.
If I disconnect the leads from the battery it will shoot up to 14 volts but as soon as I connect them again back down to 12.2 and 0.7 amps. Hooked the leads up to a 12 volt light and it provided power. Hooked the leads directly to my inverter and it powered it. But as soon as I hooked up a charger for my battery powered vacuum cleaner to charge the battery it instantly crapped out.
Needed some help, thank you.
Hi Quinten,
It sounds like something is wrong with your charger. Please contact your seller to arrange for RMA/warrantee.
Kind regards,
Lambertus
Hi, got the same problems.
after many years rare usage stopped working.
issue as you describe.
could you solve this problem, how?
many thanks, vladi
Hi Igorter,
i got the same problem as Quinten.
However, i think my device is out of warranty.
Do i have now one electronic brick or could this issue be easy (cheap / free) solved?
blue smart charger ip65 12/15 A302
serial number HQ1750MMFWT
Firmware v3.21
Bootloader v2.07
I am currently on Gran Canaria, Las Palmas
Can someone help? Who can help?
Thank you
kind regards
Vladi
Check the internal relay.
And mine has done the same thing. I’ve got a 12/15. I did an update on it a few days ago and my battery at 11.8v with only 0.8A coming from the charger. I thought my battery was stuffed because it’s pretty old but I put my other charger on it and the voltage is coming up, my other charger is saying it’s outputting 15A so now I know it’s not the battery.
As an experiment I changed the 12/15 over to power supply mode, set it to 14.4v then reconnected it to the battery, instantly the charger output drops to 11.8v with 0.8A output
Periodically I have the same issue for my Blue Smart IP65 12v/10
